722.6
arch50
airdrie
1999 clk 320 coup sold now a 2003 w203 270 cdi 120k
hi guys my 2002 270 cdi with 125k the gearbox is slipping ( code 2502 )are the internals of all 722.6 auto boxs the same £200 for a rebuild kit for the 722.6 i was going to get a autobox from a breaker and then rebuild it and then just fit it to the 270 cdi
Has an oil and filter change on the box made any difference ? Most members will recommend the change every 40k miles .
Yugguy
Rugby, UK
C220CDI W204 Elegance Comand
Only differences between the various 722.6 boxes is the torque they can handle but I think that is to do with the hardware and not things like filters, seals etc.
Yugguy
Rugby, UK
The parts code for the box indicates the torque rating but it is hard to find.
All 722.6 boxes are not the same. There are variations in ratios, number of clutches, thickness of clutches etc.
Best to get the full code and find one the same.
The 722.6 is a gearbox family sharing a similar design but there are significant variations in the details.
Jim2
Now
Now that would have been too good to be true............:) Are the box's individually numbered, like a chassis? or is it a generic nr for each type of box?
Regards, Jim2
Like engines. There is a 3 digit main code followed by a three digit sub code.
If you fit the incorrect box problems may range from poor shifting through to limp mode.
Jim2
Yes that figures....like when the early DMF's started to fail, in a lot of cases, they were replaced with solid flywheels....with consequences (and not good ones either !! ) for the gearboxes themselves. Moral of the story, replace like with like.
A
arch50
airdrie
hi guys thank for the info so i will have to go the take it put and strip rebuild then put back in well i do love my merc 16 years old or not
cheers and thanks again
Westheath
South London
Get the torque converter changed as well.
barnaclebill15
newcastle upon tyne
clk220cdi/2006/diesel
When I needed a second hand box my indie (ex MB garage foremen) said I was lucky it was not a 270 as only a 270 could be used, mine being a 220 gave more choice.
