81 W123 300D Transmission question
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by hockeyanimal, Dec 29, 2012.
  1. hockeyanimal
    hockeyanimal Active Member
    32
    Oct 1, 2010
    Narangba , Queensland Australia
    Your Mercedes:
    1977 450SEL 4.5, 1986 230TE 2.3, 1990 190E 2.0 carb, 1996 E220 2.2, 2005 Vito 2.1 deisel
    My old 300d has so many woes that I determined that a transmission swap was required.
    I managed to source a transmisssion from a guy 200 miles away (but that is a loong story for another time) and there appears to be one key difference.
    The "new" transmission does not have the modulator valve but the hole is capped and there is a shaft towards the front of the transmission that isnt on the "old" one.
    Are these two interchangable?
    What do I need to change out of the old and into the new (please tell me I can ditch the modulator)
    Where is the shaft meant to connect to?
    Help if you can please
    Old Tranny number 123 270 2801722.118 02 14 1486
    New tranny number 123 270 0701004304
  2. television
    television Always remembered RIP
    164,074
    309
    Your Mercedes:
    This will take some searching I may come up with something
  3. OP
    hockeyanimal
    32
    Oct 1, 2010
    Your Mercedes:
Share This Page
