'84 500SEC Engine Fax always on! Help!
lessteaks
'84 500SEC Engine Fan always on! Help!
Hi all,
A few months ago when I turned the car off the engine fan remain on. I disconnected the battery and then removed each relay in the fuse box and clean the connectors before replacing. When the reconnected the battery the fan had gone off.
Since then (not 100% if exactly since then but presuming so) as soon as the key is in position 2 the fan comes on and remains on constantly while driving.
Can someone please recommend a solution??
I'm a complete novice by the way so there's no such thing as too much detail!
Any advice much appreciated,
Regards,
Les
Is this the engine fan or the heater fan
L
lessteaks
Sorry Malcolm,
It's the Engine Fan!
L
lessteaks
Thanks BlackC55,
Excuse my ignorance but how can I check/ fix this?
Cheers,
Les
MBNuB
Hants
www.gyrocopterexperience.com
W204 220CDI R172 SLK
Swap it with another relay of the same spec.
If the fan relay is stuck and its replacement isn't, the fan won't come on, but whichever device is controlled by the other relay will.
Just an idea...
L
lessteaks
Thanks for that.
Which relay is it?
Stevie A
Scotland
I'm with Malcolm, make sure you buy a new or check the coolant temperature sensor too as that can cause the fan to stick on.
