Hal Fisher
- Aug 24, 2004
When I first received this car it would idle ok 50% of the time. Other times it would light its ABS light and idle fast. I orginally thought it needed a tuneup so I wasted $150 doing that (replaced wires, plugs,cap/rotor myself) no help. It has since started getting worse to the point where it never idles correctly all within a few hundred miles.
I noticed timing was around 17 and vacuum was about 14 Hgi (when idling correctly). What are the correct readings for this?
Things I have tried:
1. Easy tune-up (aforementioned)- No difference.
2. Disconnected the Cold Start Injector- Disconnection drops idle but idles very rough even when warm.
3. Spraying water mist around whole intake and vacuum port areas. - NO CHANGE what so ever (vaccum with fast idle around 22).
I guess the BEST quetion is where Is the Idle Control Valve on a 500sec?
