wandawoods
the car is a 1988 420SEL w/166k miles, and this car has been thru a lot! in last 24-mont, we have replaced:
timing chaing
16 volves (were bent caused by broken timing chain)
power steering pump
starter/alternator/battery
motor mounts
front brakes and suspensions
flex joints at transmission
all 5 belts
(1) after engine has been heated up (about 90f coolant temp) after said 10~15 min worth of driving. sporatically, the engine refuses to start after short stops!
we have replaced starter, alternator, battery with new ones in last 30-day.
when it happens, we can hear the starter trying to crank up, and it feels like gas is flooding the ignition even with very little or no gas paddle depressing. we have to wait a few minutes, then it will start. it never happened when engine was cold (1st morning start)!
(2) the idle speed in 'drive' with brake pressed is 700rpm, but in 'park' it goes up to 1200rpm. pretty weird!
(3) AC will come out from windshield/left & right/rear seats, but it refuses to come out from 3x center positions above stereo, and floor
(4) while unlocking driver door, it may trigger factory alarm sporadically, then we have go around and use the key at passenger door to stop the alarm.
thanks in advace if someone can give me a diagnosis!
timing chaing
power steering pump
motor mounts
all 5 belts
