s_sprry
my 95 e300d ac cools ok when sitting at idle (40-45 degrees out from vents) but the temp goes up 10-15+ degrees when on highway. I know the compressor is on when on highway because if I hit the econ button the temp goes up to outside temp or above. Also if the ac fan is on high the temp goes up 10+ degrees. Since it's cooling ok at idle then freon level should be ok? Could this be a bad expansion valve or bad mono valve or weak compressor?
