jamesjedi
First post here. Hi Everyone!
I have 1996 C280 not starting. I removed the key cylinder a while ago due to the key/tumbler sticking, and have been starting it with screw driver without any problem (the generic key I bought from Ebay did not work). The dealer wants alot of money for it to be fixed correctly, I will get to it.
Here is the story so far;
- I have taken starter out and tested - it works
- tested the voltage to the starter - the large one from battery has 12 volts
- tested the smaller wire to the solanoid while cranking the ingnition switch - NO VOLTAGE
I am a little stumped! As the 96 does not have a starter relay ( that I can find?), what is the next likely cause. I am starting to think that the ignition switch could be at fault. How do I test it?
Any help would be greatly appreciated. Thanks!
