A/C Compressor for...
Dosco
W211
my E240/W210 - 1998.
It has been confirmed that the above has a serious leaking seal verified today by 'Herts Merx' using an ultra violet light which shows up the dye introduced into the refrigerant about 4 weeks ago, plus of course oil is all around the front of the engine.
So any advice as to where to obtain a replacement compressor, not MB as I doubt if I could raise another mortgage at my time of life! in any case the cost would far outweigh the value of the vehicle:shock:
Refurbished compressors any thoughts? and any recommendations on suppliers would be appreciated. not:cool:
D
Dosco
W211
Thanks...
Thanks for the info. The only supplier I could find quoted me £398.00 PLUS VAT!
We have had some post where people change the O ring that is at fault. There are firms that re con them, and I hope to find some
D
Dosco
W211
124coupe
The original compressor should have its OEM maker & part number on a sticker or plate - you may find cheaper options using that to supplement the search.
E.G. for my W124, the original fitted compressor OEM is Seiko.
