Richard Murray
My wife's A-Class (1999 T-Plate), 168 model, 1.6 injection has started playing up. Fault started with car failing to start - which was attributed to a faulty battery (which has now been replaced). Also the rear wiper remained on all the time. To stop the window glass becoming scratched - I've disconnected the rear wiper at the socket after removing the trim in the tailgate.
Today - the front window washers refuse to operate, the rear window element won't work (no tell-tale light on button) and the CD player won't play CDs shows [error] in the Blauplunk display. Also when you try to operate the front window washers - [SRS] supplemental Restraint System displays in the dash. I don't think this is connected to the airbags or seatbelt pre-tensioners. Incidently - the window washer pump doesn't sound, so it has to be electrical - and not simply a loose connector hose or blocked water jet.
Before I take the car to a Bosch specialist (not MB stealership) I assume this is a faulty relay or poor earth connection - can anyone point me in the right direction please. Thanks [Television] for advice to date.
Richard
Richard
