Phil5698
New Registration
- Apr 21, 2019
- A Class 2008 1.5 Auto
My in-laws have an A-Class 1.5 Petrol Auto 2008 and it's developed an intermittent starting problem. When the problem occurs the engine doesn't attempt to start. Everything lights up as it should when the ignition is switched on, but it won't attempt to turn over. It seems to happen not from cold but after a run. Which kind of makes it worse because they're out somewhere and not at home when it happens.
The first time the AA came out and although by the time they got there it was starting they sold them a battery. This hasn't cured it. It's happened a few times since and after some time it just starts.
I've read a bit about potential ignition switch problems or starter motor issues. However, I'm not really sure how to advise them to move forward. Would a diagnostics check help to point out an ignition switch problem? Is there an easy test to see if the starter motor is on the way out- which seems like it'll be a nightmare in labour if it is :/ ?
If it's not something I can check/diagnose myself, does anybody know somewhere in the Solihull / West Midlands area who could diagnose the problem? My concern with it being intermittent, is that that it won't be that easy to replicate/diagnose and they will end up blindly throwing money (that they haven't got) at parts/fixes to get it sorted.
Any help will be greatly appreciated.
Thanks,
Phil
Thanks,
Phil
