W
Wingnuts
A150 W169 2006 Manual Petrol
Help please, Happened out of the blue, car was fine until I turned it off, it sat in a rain storm for 10 minutes when I went to start it it wouldnt start.
It turns over and tries but gives the impression there is no fuel then after about 10 attempts it will start and at once settle to a normal happy tickover and run perfectly. It will then restart OK until it has been stopped for some time (say 1 hour) when the whole problem repeats.
As I say it is as if it is taking time for petrol to get through until it has been cranked.
Where do I start? Its not as if it is only when cold.
Is the fuel pump a contender and difficult to replace?
Would MB diagnostics be likely to find it if its intermittent as it might start OK if I took it to them?
Thanks for looking.
Thanks for looking.
