a class
s and k autos
middx
320 SL 300 E 124 SHAPE
hello does any one had there esp abs light on done test and got c1140 and c1504 steering angle sensor any ideas thanks
Cole@MBS
www.mbssouthampton.co.uk
Yes, seen it a few times now!
9 times out of ten new angle sensor needed,
Is the steering wheel straight??
Cole@MBS
On the steering column, just behind steering wheel, theres a lug that fits into the rear of the wheel!!
s and k autos
middx
yes the wheel is stright is merc only part or can i get it from euro and thanks again
Cole@MBS
Not sure, only ever fitted Merc ones!!
What machine did you get the faults codes with!!
Cole@MBS
Dont know that one!
Where they currant or just stored faults??
Cole@MBS
Well thats got to be the first place to start then if there the only codes!!
Alex Crow
Super Suffolk
just to add to colin`s informed, experienced and always useful input. i have seen 1x A140 that had recurring angle sensor faults even with a new sensor. turned out to be play in steering column affecting the sensor alignment (uses optical sources and receptors, interrupted by moving tabs. tabs not going far enough into groove and causing fault).
Cole@MBS
Yes, agreed, see that once Alexander!
Also had the U/J knocking like hell!!!!
Cole@MBS
Crap idea, would say, only good for left hand drive. but the fault is the same in germany!!!
