James T Notts
- Feb 27, 2018
- Mercedes CL180 Kompressor 2005
Hi Guys,
I have just joined up as I have a couple of questions that you guys may be able to help me with. My car has been in the garage and come up with a few error codes regarding the brakes. Now the garage advised I ask on here if anyone knows what the codes are saying is the problem as they could end up spending a lot of time and money testing things to try to work it out. The codes are;
C1141 - electronic stability program brake pressure sensor - B34 plausibility error
C1038 - engine ECU not identified, or incorrect
C1112 - speed sensor front right L6/2 signal fault
C1102 - speed sensor front left L6/1 signal fault.
The other question is simply what length dip stick do I need for this engine.
I would appreciate any information and thank you in advance.
Cheers
James
Cheers
James
