Do you have the ASSYST service computer in your car? It is the ASSYST that decides A&B on the 'older' Mercedes and A-H on the new ones. I didn't think ASSYST went back as far as 95 so yours will be simpler and follow the service booklet.ok then, what is a B service about then ? brakes and so forth or much more ?
my next service is due @ 195,000km and i have no idea if it should be A or B, last service was oil/filter
cheers
anyweb
Not at the MB Dealer I use. They drain the oil out of the sump plug. I take a look at the crossmember for rust everytime it goes in for service.They dont even remove the sheild as the oil is sucked out of the dip stick, sadly.
i don't have assyst so i guess i'll just let my local indie decide whats best,
next service due in about 5000km
i replaced the brake discs all round about a year and a half ago so i guess they should be alright, but the brake pads might need changing
cheers
anyweb
Well actualy they check your lights, oil locks and hindges generally check it over, but the basis is that it's an oil and filter change. If it's a newer Merc then they reset the service with Star as well as add it to the comp base for future resale and warranty/breakdown cover and stamp your book. If it's put on the star it automatically checks to see if it is due any flashes, (updates to the sofware).
