A sick E320
Jay Gee
N.Wales
Honda
I've been offered a '57 reg V6 E320 that's had a bit of an incident.Apparently it made a 'ping' noise,the dash went red,the engine stopped,and a bit of smoke appeared from under the bonnet.The owner(whom I know well) told me that the only damage,from a cursory glance,seems to be to two wires going to the turbo area.The car won't turn over on the starter now,so-I have been offered it at a good price(not yet discussed). Is it worth contemplating.Any ideas as to cause and any further effects? I'll ask the piece of string question later.
Can you call out the AA/RAC to confirm the problem before you discuss price ?
Jay Gee
N.Wales
Honda
Thanks for the reply,but I thought I would run it past the forum first .
Cole@MBS
Hedge End, Southampton
www.mbssouthampton.co.uk
124 300 CE 24 Coupe, 209 240 CLK
It’s always a chance J.......has the damage gone further back up the loom and killed something very expensive like the engine ECU or just a small short on the loom..........I always consider the most expensive repair at worse way then if it turns out simple ( never does ) your quids in...........to kill the car dead like that, I suspect something pretty major has happened.........
Jason Evans
London and Hatfield, Herts
W211 E320 CDI
With the complex electronics on these cars I would personally stay clear. Like Cole says if it's spead to other components then it could be a costly exercise. The fact that it would not start is worrying. Get it on a diagnostic machine to see if there were any errors reported and then go from there.
What mileage is the car and what price discount are we talking ?
Jay Gee
N.Wales
Honda
Thank you all for your input. Cole pulled me back from the edge of the precipice with this one,I think.
bembo: the car was being driven at the time,albeit slowly.
Wighty : Mileage is 177k approx,but all is academic now as I had decided that this was going to be a black hole
and when I went for a chat this morning,the owner told me he has decided to sell it off as parts.Still it would be
interesting to find out what happened.I'll try to find out and report back.
bembo449
gainsborough , lincolnshire
at that mileage it will have got well past a lot of the common faults , will be interesting to see if you can get a fault diagnosis pal
dbanbery
Huddersfield
1995 R129 SL500
I heard that a starter motor fault causes this type of behaviour, albeit slightly older cars
Gtechniq manufactures an ultra durable and comprehensive range of surface protection products for cars, boats, RV's and aircrafthttp://www.gtechniq.com
