A Tip for removing snapped radiator drain plug
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by Silver_Star, Oct 27, 2012.
  1. Silver_Star
    Silver_Star Senior Member
    2,294
    8
    Apr 20, 2009
    Rural Leicestershire near where Pork Pies and Stil
    Your Mercedes:
    W203.006, S211.208 Land Rover 90
    When I first got my 203 nearly 4 years back now, I noticed the head had snapped off the red radiator drain plug.....I found the head in the under tray when I removed it. I must have had the replacement plug for getting on 2 years now!:lol:
    Anyhow, yesterday I was giving the car a service and needed to change the coolant. So naturally tackled it.
    All you need to do if this happens to you, is get a soldering iron and melt a slot to fit a flat headed screw driver in and you will be able to unscrew it.
    [​IMG]
    [​IMG]
  2. television
    television Always remembered RIP
    164,074
    309
    Your Mercedes:
    Very good tip :D:D, soldering irons are so useful for doing other jobs with plastic
  3. spock500
    spock500 Senior Member
    890
    Apr 5, 2008
    Milton Keynes
    Your Mercedes:
    300TD, 1998
    I went to clean the MAF the other day.
    Despite having most tools, I didn't have one for the torx screws which had a prong in the middle.
    MB are making every attempt to thwart the home mechanic from servicing their own cars, well not quite.
    10 mins with a trusty hacksaw and two perfect (kinda ;)) flat head screws!
  4. television
    164,074
    309
    Your Mercedes:
    The prong in the middle is a security torx, and many sockets come with the holes in these days, the worst screws are the do up only :confused:
  5. spock500
    890
    Apr 5, 2008
    Milton Keynes
    Your Mercedes:
    300TD, 1998
    It's an odd thing to have security bolts on?
    I just can't see the casual tea leaf thinking, "'ello, that's look a tasty MAF, I'll have that"
    Is it maybe, anti tamper to stop us changing it, bit like the sealed for life gearboxes?
  6. television
    164,074
    309
    Your Mercedes:
    The answer to that is,, if you can get the sensor bit on its own, it will cost £70, if you buy it with the plastic pipe that its screwed in then £180, that make it the most expensive bit of plastic tube in the world
  7. Frontstep
    Frontstep Senior Member
    7,393
    1,276
    Apr 22, 2007
    Your Mercedes:
    T210 320cdi
    So its for the convenience of the customer to save them unscrewing it and spending too little.
    My drain plug snapped as well, hewn from special carrot based plastic
  8. television
    164,074
    309
    Your Mercedes:
    That is a very good way to look at it :D:D
Share This Page
