a140 1999
blackface
New Registration
guernsey
a140
just bought a non running 140 petrol manual year 1999 was told it was the ecu stopping it run so had that rebuilt turned over but plugs wernt wet so removed the after market imobiliser had a spark and wet plugs then it fired up and died after 1/2 seconds so thought might be fuel pump as whemn it did start a frd sprayed brake cleaner in the air intake and while he sprayed it it kept running so checked fuel filter and pump and both ok! had merc garage say it was in there opp the original merc imobiliser still fitted ?????????? any ideas what to try next?
Probably the MAF built into the ecu
