A140 Classic rear washer problem.
Status
Not open for further replies.
P.C.
Liverpool
Rear washer not reaching rear window. When pressed water appears to be running down within the rear door and coming out of the drain holes. Pipework must have come adrift inside. Any help to fix very gratefully received. With thanks. Paul.
piestore
manchester
a rear washer
HI
Its not a nice job you have to remove the washer jet and fish the pipe out from within the door to reconnect it put plenty off screen anti freeze in to stop it happening agian. The othe common pnoit for a leak is in the trim just above the rear tail gate but this results in water inside the car
500sl
Banned
london
www.imadick.com
Re: a rear washer
piestore said:
HI
Just use a piece of wire to reach the pipe and reconect it
Ps mr noall's spelling is bad.
Status
