A160 '98 very noisy gearbox, pricetag?
Fritz80
Belgium
the gearbox has some singing bearings that need to be replaced, problem is that there's probably more worn then only the bearings.
Does anybody has an idea what this costs? a new gearbox or revision of the old one? Does there exist a partslist with prices somewhere on the worldwibe web ?
thanks
Hello Fritz you do not say if auto or manuel
Malcolm
It is normally the lay shaft bearings that go, if left too long with the gears out of meash it could mean replacing quite a lot. Gear boxes are a specialist repair item.You need a lot of knowlege about thrust. have you thought of asking a gear box center for a quote or go to a breakers
Malcolm
F
Fritz80
Belgium
I will search for a gearbox center! I have contacted a breaker, the price for an 90.000mile item was £600. My car has also around 90t miles..... I don't want to get all that work done to find out that the "new" gearbox also begins to sing and rattle.
