A170 cdi blocked injectors...PLEASE HELP
Lloyd1
I have been told my A170 cdi (2002) has 1 or 2 blocked injectors and the cost of repairs will be (approx) £800 -£1000. I have tried the Redex injector cleaners with no success. Has anyone any suggestions as the money is a real problem. The car runs very `lumpy` and sounds like a tractor on tickover. has anyone any advise PLEASE.......
Hertfordshire Merx
A160
Have seen dealers try allsorts in an attempt to clear injectors for one reason or another and they have all failed. Its nearly always in internal mechanical fault in them. Only answer to repair properly is to replace them. Sorry:neutral:
Cole@MBS
www.mbssouthampton.co.uk
124 300 CE 24 Coupe, C220CDI,
You cant have "blocked" injectors, as the car wouldnt run, undo one injector pipe while running and it will cut out, think you need someone who knows how a merc cdi system works!!!!
L
Lloyd1
Sam, have you any suggestions as to how to sort out the problem?
Lloyd
Cole@MBS
Got to agree with H/M, sound like new injectors needed, would need to see the car to really understand what is going on!
L
Lloyd1
the car has 130k, it has been on the diagnostics which showed one injector very low reading (blocked injector), 2 cylinders fine and the forth very high reading. He thought that the high reading was due to it `over compensating` for the blocked injector. Either way it sounds like a Massey Fergusson and the wife is sick of it and giving me earache. trouble is the money. so far I have spent £40 on injector cleaner without success. someone said you could put the injector cleaner into the injector `neat` if this is possible? Any help would be appreciated. Thanks Lloyd
Cole@MBS
Its not as easy as it sounds, plus, the new electronic injectors dont clean out like the older ones, some companies can re-furb them, that might be a cheaper way for you!
5pares
Suffolk
E320cdi
Where are you based?theres prob a good indie near you.
A170Guy
Injector Problems
Hi there,
Just came from MB dealer and they want 1500 to replace my wife's A170 injector!!!
I cannot afford that for now!!!
Does anyone know if I can source it elsewhere asides MB dealers?
What causes the injector to go? Rich diesel? Running on reserve tank?
Cole@MBS
Where abouts are you, think a second opinion from a indi!!
Welcome to the forums!
A170Guy
Injector Problems
A garage that serviced the car last said that I should take it to MB for correct diagnostics...
He said that it could be expensive!!!
I am based in Dartford kent!
Thanks!
Did not expect a swift response!!!
Cole@MBS
I was born in dartford, westhill!
What is the fault with the car, then might have a clue why there quoting that amount???
A170Guy
Injector Problems
Wow,
I live very close to westhill!!!
Thanks!
The engine idles rough! but once it gets going, it's ok until I have to stop at the next light!
mpg is down too!
MB dealer says that there's high pressure in some of the injectors... They suspect air in injectors...
Cole@MBS
Air in the system would cause this, but with air in the system, your main fault would be non starting from cold! dont know any indis around dartford, only lived there for 30 years!!! maybe someone on the site will throw a name at you who you can trust!!!
Tango
Hi I have this same problem - engine chugging, very noisy on idle - max speed is about 80-90 with the car shaking like anything. its been like this for approx 6 mths now is it going to get worse?? Is there no fix other then new engine??
thanks
