A170 cdi lack of power
Colare
Kent
ML270CDI Y reg. GS1200 07 reg. 3008 10 reg.
Hi Guys
X reg A170cdi with a lack of power, starts and drives fine with no warning lights coming on. Had diagnostics done at MB and came back with injector 2 leaking inside (MB words) and a sticking turbo actuator.
Q. would injector cleaner help or should I bite the bullet and fit a new injector?
Also is there a way of freeing or lubing the turbo actuator?
Thanks for taking the time to read this.
Colin.
Injectors are a common fault!!
At a guess on the turbo, i would try a turbo vac transducer first, there more common on a A,class!!
C
Colare
Kent
Is the transducer an easy job?
Couple of pipes and a electric plug, thats all!!
Follow the rubber tube of the waste gate and your find the transducer!!
C
Colare
Kent
Great, thanks for your help, will keep you updated.
C
Colare
Kent
Spot on turbo vacuum transducer!
