Så - the glow plug light on and fault codes for all plugs not in function and 2267.
The 2267 was the signal (?) wire on pinn number 1 (blue/black thin wire) was OFF. I triet to solder it together the best I could - it was off 2 mm from the electric connector and I was not able to get the female pin out from the connector =(
After that all four glow plugs still gives fault codes.
Any ideas - I have just changed the ****** thermostat and in the same time cleaned the "mixture chamber" from couple of deciliter soot!! Strange the engine even run!
And to even get to the glow plugs I would have to do all the work again....
I had the "relay" out and opened it and looked at the components and all looked fine.
Any ideas how to search fo the fault and pinpoint it before I have to remove half of the engine again?
Pics of the throttle pdy and the mixing chamber.
