simonllawrence
New Registration
I have just got my car (SL500 r230 2003) back from a Independent garage that has replaced the transmission control. On my second day of driving it i got the dreaded ABC red drive carefully message. I have just checked the ABC fluid (See picture 1) and it appears to be below the top two notches in the middle. Am i right in thinking it should be between the top two notches when the car is parked and not started?
Also while investigating the fluid level i noticed that there appeared to be a greenish fluid welled up on a component just below the ABC fluid tank. See picture two . I dipped my finger into the fluid its a couple of millimeters thick. My question is what is the component with the fluid on it? Should there be any fluid on that component. Is it the source of my ABC fluid leak? Could this have been damaged when they fixed my transmission control or is it just another fault that coincidently started around the same time.
