Hi, I have had a Mercedes for a few years which has been pretty much faultless but has since developed a strange fault.
I managed to burst a brake line the other month which I replaced but that meant needing to bleed the brakes back up which was problematic to say the least, I just couldn't get the fluid back towards the pistons. I know you are supposed to open the ABS module electronically but eventually I got it to flow by pressure bleeding them up and the brakes work fine now.
However before I used the pressure bleeder I decided to spin the back wheels of the car whilst it was on stands to see if the rear brakes were doing anything at all. Now obviously the car though the back wheels were moving but the front ones weren't and it immediately threw up a traction control error and cut the power. I switched off the ESP and carried on but ever since then the ABS and ESP warning have been on and won't go off.
I'm sure I didn't damage any wheel sensors when messing around with the brakes and what I did cant be any different to spinning the back wheels on ice or similar. Why would the error be constantly there? Also note that the error popped up before I used the pressure bleeder so it can't be that thats caused the error.
Thanks for any insights.
