humbersin
Hi all,
I'm a newby in the forums.
I have heard or read somewhere that I can avoid expensive repairings costs of my ABS ( C180 Elegance, 1999) by swapping the ABS with the windscreen liquid level indicator and trick the MOT as the lamp will light up in the key position 2 and will turn off after starting the engine and will not show any malfunction afterwards.
Perhaps it sounds a little bit naive but I hate the ABS anyway.
Can anyone tell me where is the connector of the ABS located which is similar to the one of the windscreen liquid level in the plastic tank (as I can't find it) or wheather it requires a little bit more than a simple swapping, say cutting connectors or any sort of re-wireing.
Thanks,
Humberto
Thanks,
Humberto
