robdx
- Sep 8, 2013
- Location
- huddersfield
- C180 Kompressor Classic 2006 W203
Hi all
I have a 2006 C180 Kompressor, trouble free for 18 months and do a lot of miles in it and it doesn't miss a beat, the auto gearbox is very smooth and the engine purrs. About 2 weeks ago I took a box of beef(work at a butchers) to a customer on my way home and one of the packs must have leaked as i started to notice a bad smell, I took out the back board and cleaned it but it was still there so I emptied out the spare wheel etc and scrubbed out the back with plenty of water and bleach, in fact i poured in the liquid and scrubbed so it got pretty wet, though i dried it off afterwards.
Once I set off a good hour after scrubbing it came up with ABS fault and ESP fault and its in limp mode, no gear shift and couldn't manually overide, I pulled over turned off and restarted but the same again, so i turned round and went back to the unit, i tried turning off and on while moving then the alternator light came on and straight off then back to ABS and ESP fault so I have left the car at work and come home in the van. Would it be reasonable to assume that because it was fine up till the point of scrubbing it out that I have got something wet?
Will it dry out and clear over the weekend or is it just a huge coincidence
Any help or tips massively appreciated
