ABS Pump Replacement
M
mkinspain
Having the ABS & BAS dash lights up for some time, I have been informed, after diagnostics that the ABS pump requires replacing, part number A 002 431 92 12. As this is an expensive item, is it something I could change over myself as I am not too bad with the spanners, however not sure about the fluid part of the operation. I hope someone can advise if you think this is the answer to the problem and if the change over is easy enough to do. Many thanks
Cole@MBS
www.mbssouthampton.co.uk
What car, i have a couple of 2nd pumps kicking about which are good!!
turbopete
Spennymoor
as samunit already said, knowing what car you have will help with fitting advice! finding a pump should be no big problem. you have a part number. could be same no for an a class, c class and ml (for example only) and the fitting advice would therefore vary considerably!
M
mkinspain
Thanks, its a 1997 C180 auto W202
M
mkinspain
Abs
Thanks, its a c180 1997 W202.
M
mkinspain
Could you tell me the cost for a unit, thanks
www.ckinsurance.co.uk
