ABS, Traction Control, EDC, warning lights, illuminated and Spoodometer not working.
Raymond Hanlon
Sprinter 616cdi year 2005
Mercedes Sprinter 616cdi, year 2005.ABS,Traction control, EDC and brake fluid warning lights illuminated and Spoodometer not working.Anybody any idea what the problem maybe, thanks Ray.
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
As above. Low voltage produces lots of faults.
Get the battery charged up or replaced before the really cold weather arrives.
M80
Derbyshire
I think your spill chick is faulty.
R
Raymond Hanlon
Battery is fully charged and the vehicle starts first turn of the key.
Uncle Benz
West Sussex
Mainly Mercedes
Read the fault codes. You probably have a bad wheel speed sensor pulling the whole system down. If that is the case, take my advice and buy a genuine mercedes sensor. The aftermarket ones read double for some peculiar reason. Don’t make that mistake. It’ll make you doubt your original diagnosis
R
Raymond Hanlon
R
Raymond Hanlon
Thanks for that piece of advice with regards to the genuine speed sensor. Have struggled to get a local garage to do a diagnostic check as the Sprinter has a14 pin plug and not the standard 16 pin Obd plug. Taking it to a garage tomorrow to hopefully get a diagnostic check carried out.
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Could be the brake light switch. Whatever is causing it , its a canbus error. Don't waste time guessing have an expert with the tech to sort it.
R
Raymond Hanlon
Hopefully will find out tomorrow if the diagnostic scanner can pick up the fault, fingers crossed.
R
Raymond Hanlon
Hi guys connected snap on diagnostic tool no code showing when you go into ABS module as if there is no power going to abs system, any ideas
onefortheroad
uk.
Snap on isnt the best kit. Get it on star.
onefortheroad
uk.
If its anything like my e350 if its a canbus fault, the abs system will be fine, when this fault occurs your device cant talk to the abs systems. It tricks you into thinking its the abs at fault , trust me its not. My problem was down to a headlight ..... I'd lose power steering, pre safe , speedo , abs , esp, all the rear lights would light up and stay on, car wouldn't go into drive. £42 On star scans the vehicle properly.
R
Raymond Hanlon
Thanks for the Info, I did have a rear tail light out changed that and also checked brake light switch which some people say can cause the problem also but no success as yet, looking at possibly a broken wire somewhere but not the easiest of things to work on, thanks
onefortheroad
uk.
Pay for a star session. Don't pish about .
