It's turned off.
I much preferred that Mercedes way, rather than the now red light on is AC on.It's turned off.
No light = on.
Red light = off.
Then there is a fault in the system.Hi the red light stays on if press it on and off
Pretty sure that's the old system. Modern ones are permanently engaged and vary flow rate.Then there is a fault in the system.
With the engine running and bonnet open you should be able to see the clutch on the AC compressor switch on and off when the button is pressed.
If the clutch doesn’t cut in when the switch is pressed its most common that you’re out of gas. Get it pressure leak tested as you may have a leak. Repair the leak then regas.
2002 car...Pretty sure that's the old system. Modern ones are permanently engaged and vary flow rate.
Ah yes...2002 car...
“Rest” feature is still available. I have it in the SLKA nice feature on that generation, turn off engine touch A/C button & the heater remains on for an hour. Great in winter, make sure the heater fan is on low speed.
Yes it was on our old 171 2010 vintage.“Rest” feature is still available. I have it in the SLK
