Acid or Acid free wheel cleaner ?
SATURDAY KIDS
Poole
EQC 400 AMG Line Premium Plus
Hello All, I'm back after a three year sabbatical to BMW ! Just picked up my new EQC from MB Poole today and it's lovely, especially the beautiful 21" wheels. My question is regarding the cleaning of these and if the acid free wheel cleaners are preferable. I was about to order some through Poor Boys but thought it worth getting an opinion first.Image 2.jpeg
Woodleigh
S213 - AMG E 53 - 4MATIC - Premium Plus - Night Edition - Mild Hybrid Estate.
Koch Chemie Reactive Wheel Cleaner for me; its acid free and pH-neutral...if you can stand the smell. Lol.​
SATURDAY KIDS
SATURDAY KIDS
Poole
Thanks all. Confirmation all round to make sure its acid free.
Whilst I'm at it....tyre dressing ??
Woodleigh
Gyeon Q2 Tyre Gel
Uncle Benz
West Sussex
Mainly Mercedes
If you see an “Autosmart” van on the road, follow it until it stops. It won’t be long. Ask the driver for 5L of Red Seven and a mini jet spray bottle. It’s probably the best acid free wheel cleaner you can buy. Only officially for the trade, but most Autosmart franchisees will sell to you if you ask nicely.
SATURDAY KIDS
SATURDAY KIDS
Poole
I'll keep an eye out !
malcolm E53 AMG
You’ll love the EQC my son has one he’s very impressed and so am I it would be my choice if I wanted a EV best value for money out there
SATURDAY KIDS
SATURDAY KIDS
Poole
Very nice after just one day so far. Nice to have a few bits on this one too, the Burmister Sound system is significantly better than the BMW I PX'd.
malcolm E53 AMG
The EQC is very well engineered, based on the GLC chassis and benefits from a really plush interior especially the Premium Plus - enjoy the car range isn’t the best but everything else is
rich.g.williams
Mercedes C200
Hmm acidic wheel cleaner - not thought about that before but these observations might help:-
"Washing up liquid's generally alkaline (pH 9-10), not acidic. It can still corrode aluminium alloy wheels though, especially if:
- Prolonged exposure: Leaves residue that attacks the alloy.
- Not rinsed properly: Trapped moisture and detergent accelerate corrosion"
"Pressure washing with water ASAP (minutes after applying cleaner) can help prevent corrosion by:
- Rising off residue: Removing potentially corrosive cleaner.
- Reducing dwell time: Limiting exposure to the agent.
But, if the cleaner has already reacted with the alloy, some damage might be done. Wheel material and cleaner type matter too"
"Generally, road salt's a bigger problem for wheels than cleaners. Salt:
- Penetrates crevices: Gets trapped, causing pitting and corrosion.
- Long-term exposure: Constant contact, especially in wet conditions.
Cleaners can cause damage, but Salt is a sneaky, ongoing issue. Regular wheel cleaning helps mitigate salt damage"
"Let's look at reaction times:
- Acidic/alkali cleaners: Can start reacting within minutes if concentrated and left on wheels. Damage's often more cosmetic (e.g., staining, etching).
- Road salt: Can take hours to days, depending on moisture and exposure. Damage's often structural (pitting, corrosion) more serious.
"Some wheel cleaners are pH-neutral (around pH 7). Look for:
- "pH-neutral" or "neutral pH" on labels
- "Safe for all wheel types" or "non-corrosive"
What is the best PH to remove salt - "For removing salt, a slightly acidic pH (around 5-6) can help dissolve and lift salt residues. Some wheel cleaners designed for salt removal might have a pH in this range. However, be cautious with acidic cleaners on certain wheel materials. A pH-neutral cleaner with surfactants can also work well if rinsed properly"
"Industrial surfactant cleaners for offices usually have a pH between 9-11, similar to washing up liquid. They're designed to tackle dirt, grime, and oils effectively"
"Besides salt, these can damage wheels:
- Brake dust: Contains iron particles, can cause corrosion.
- Oil and fuel residues: Can soften or damage certain wheel materials.
- Grime and tar: Build up, trap moisture, and corrode.
- Bird droppings: Acidic, can etch or stain wheels"
"Assuming 25 mL of pH 9.5 washing up liquid diluted in 10 Litres of tap water
- Washing up liquid pH: 9.5
- Dilution: 1:400 (25ml in 10L)
- Tap water pH: Assume ~7.5 (varies by location)
with some maths and assuming ideal mixing:
- pH of the resulting mix is approx 8.2
pH 8.2 is mildly alkaline. For aluminium alloy wheels:
- Low risk of severe corrosion: pH 8.2 isn't extreme.
- Some risk of surface dulling or staining: Possible if left on wheels long-term"
CONCLUSIONS
1. Use 25mL of washing up liquid diluted in a 10L bucket of water, pressure wash off within 5 minutes.
2. Avoid road salt, never let it stay on your Aluminium Alloy wheels for long.
SATURDAY KIDS
SATURDAY KIDS
Poole
CONCLUSIONS
Thanks for taking the time to put this together. Certainly avoiding any 'acidic' cleaner.
w204benz
2012 C200CDI AMG Sport
I have only ever resorted to acid cleaners to get rid of heavy brake dust build-up in the wheel barrels that milder cleaners wouldn't shift, and even then I didn't let it dwell for more than a few seconds.
I definitely wouldn't be using it on diamond cut as if there is any damage to the clear coat it will ruin the finish. And if you clean the wheels regularly, acidic cleaners would be unnecessary.
But you should also avoid any alkaline cleaners containing Sodium hydroxide - it will corrode bare aluminium just as badly as acid.
ALFAitalia
Pagham, Bognor Regis
2010 Mercedes W212 E350 CDI Sport
People are dating about acidic alloy wheel cleaners damaging alloy.....of course it can damage aluminum alloy......but unless you have had your wheels stripped to bare metal and polished then your alloy wheels will be protected from the acid by a nice layer of paint, lacquer or powder coat so won't be able to damage the wheels surface.
rich.g.williams
Mercedes C200
You would think that to be true but in time acid/alkali/salt can find its way between the Rubber - Aluminium sealing surface (bead) and slowly corrode where paint may not exist or has been damaged by tyre levers.
You then have a very slow puncture, typically 10 psi per month.
Aluminium is a difficult metal it will oxidise in air unless protected (Anodised or painted or powder coated) even pinholes in paint will allow oxidisation/corrosion underneath the paint. Oxidised Aluminium creates white powder and leaves severe pitting. Problems can also happen on the inside of the tyre because it cannot be seen or accessed easily and does not get cleaned.
