Digsy
- Jul 20, 2019
- GLB 200D Executive
I'm now on my third MB car with Active Brake Assist. The first was a 2016 B Class, then a 2019 C Class and I just changed to a 2022 GLB with MBUX (the other two were Comand).
On the B and C I used to get the "first stage warning" for brake assist quite a lot (probably not something to be proud of). Generally when on my commute I would get flashes of the warning to back off a bit, especially when joining a queue of traffic. Also there were a couple of spots on country roads that I used a lot which would regularly fool the system into giving me the warning beep as well. A bush on a sharp corner, for example. The car never got as far as actually putting on the brakes, but I knew the system was working because of the warning lamp and the occasional "false alarm".
However, on the GLB the whole system seems much less sensitive. I have barely seen the warning lamp come on despite not really changing my driving style, and also the false alarms no longer happen. And this is with it set to "early", which I assume is the most sensitive setting.
So I am left wondering, is Active Brake Assist on later vehicles more "robust", just less sensitive, or is mine not actually working properly?
And yeah - I get it. The light shouldn't be coming on at all.
