darren1001
- Sep 22, 2021
- W212-002
I have a W212-002 (2013).
I have the following faults appearing on the dash (not now an intermittent fault like it used to be)
active lane keeping assist inoperative,
DTR+ steering assist inoperative,
active blindspot assist inoperative
Switch off engine and leave for 15mins, then restart the car no longer works
diagnostic is:
U118300 (historic) The diagnostic CAN network management is unstable
755000 (current) Chassis CAN bus: One or more signals sent from control module 'Central gateway' via the CAN bus is unreasonable
re the Central gateway (CGW/ZGW):
P061000 (historic). The coding of the control module is incorrect
The trafficators (turn signals) stop working quite regularly but only when the above warnings are displayed on the dash, and even then only after several minutes, (intermittent fault):
B178F00 (historic) Switch 'Turn signal' has a malfunction
Have had the car from new and previously replaced the RHS driver's side rear radar (A0009058702) which seemed fixed a similar problem for a few years
I was be so grateful is somebody might offer some insight into how to fix
@rorywquin am aware you've suffered similar problems yourself
diagnostic is:
