Jeffb56
Registered
Hi everyone. I’ve just bought my second S class but a diesel this time (2012 S350) and 5 days in I am regretting it I think! The Adblu warning came on and the EML at the same time so I’ve filled the tank with 20 litres of the stuff and hoped it would clear but it hasn’t. I’m waiting to take it back to the garage I bought it from but in the meantime put a code reader on it and get the following. I don’t just want to clear them until I take it back but do you think that it is just a case of the fact that the adblu was nearly empty or could it be the dreaded Nox sensors I have been reading about? Should it need a code reset? I don’t want to clear anything they may need but I note my reader (car Scanner) says the codes were reset just before I picked the car up which makes me a little suspicious…
Any advice gratefully received..thanks!
P2BAD
Raw code: 2BAD
ECU: Engine control unit
Status: Confirmed
OBDII: Nitrogen oxides (NOx), limit exceeded - cause unknown
============2==============
P2BA7
Raw code: 2BA7
Status: Confirmed
OBDII: Nitrogen oxides (NOx), limit exceeded - reductant tank empty
============3==============
P2BA9
Raw code: 2BA9
Status: Confirmed
OBDII: Nitrogen oxides (NOx), limit exceeded - insufficient reductant quality
============4==============
P1117(00)
Raw code: 111700
Status: Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
OBDII: Engine Coolant Sensor intermittent/ECT Sensor Intermittent
Mercedes-Benz: Engine Coolant Temperature Sensor Circuit Intermittent
============5==============
P16D3(00)
Raw code: 16D300
ECU: Engine control unit[Archive (inactive)]
Status: Confirmed, Test failed since last DTC clear
============6==============
P16D4(00)
Raw code: 16D400
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
============7==============
P1061(00)
Raw code: 106100
Status: Pending, Confirmed, Test failed since last DTC clear
P2BAD
Raw code: 2BAD
Status: Confirmed
P2BA7
Raw code: 2BA7
Status: Confirmed
P2BA9
Raw code: 2BA9
Status: Confirmed
P1117(00)
Raw code: 111700
P16D3(00)
Raw code: 16D300
P16D4(00)
Raw code: 16D400
P1061(00)
Raw code: 106100
