fidge
- Feb 14, 2017
- Location
- Sandwell, West Midlands.
- C-Class Coupe 2013
I'm fitting a Tracker to my C205 and want to make the install as OEM as possible for obvious reasons. I want to use the fuse box in the dash on the drivers side and can see that the fuse holders that are in there look 'plug n play'. What I mean is the blanks only seem to have one connector and the ones with fuses in look like the second connector is an add-on bit that will allow a fuse to be used.
Now my question is can I get one of these adapters/connectors to turn a blank in to a valid fuse holder?
TIA
TIA
