I own a 2014 E300 Hybrid equipped with the so called intelligent LED light system that follows the road when cornering. Unfortunately there is a dim patch on the right-hand side when on low beams about 5-10 meters out in front, which I find slightly impedes visibility.
My question is, since these are electronically controlled mechanical lights I assume they are also self-adjustable; however, is it possible to somehow tweak them such that the dim patch can be resolved? It feels as if it's a small matter of moving part of the multibeams on the right-hand side a bit to the left. I don't think the bulbs need replacing but I'm willing to consider they might -- how could I test this? The light output in high beam mode is flawless though.
On a slightly unrelated note, the lights can be configured for right or left-hand side drive. What should I pick if the steering wheel is on the left? I went with right-hand side drive since I assumed it refers to the side one faces incoming traffic. Changing this setting does not affect the dim patch in the slightest.
