- Thread Starter
- Thread starter
- #21
Ok, got car up with back wheels on blocks.
There is a small diameter cylinder 13mm ish and coming out of each end there is a thinner rod with a balljoint to allow a flexible connection at right angles via a 6mm threaded peg secured by a 10mm head nut. One end is connected to the body the other to a lever on a valve body. Presume this is operated hydraulically via two thin tubes going into the side of it to vary the length and open/close the valve which it is attached to.
One end was not tightly secured so someone has been at this before.
I removed this from the valve control arm and the car lifted and dropped when the arm was moved up or down so that side of the system is working.
It looks like the adjusting mechanism cylinder described above is not being activated or is seized,
The tubes that ran from that went under the fuel pump cover I could not see them following the fuel lines along the bottom of the car, maybe they run through the car, ran out of time to investigate further and not really sure where next to go.
Cheers
Cheers
