ADS issue (W 251)
Jan Grenner
New Registration
W251 (R-Class) / 2007 / 320 CDI
I have an ADS switch in my R 320 CDI (sport/comfort), which lights up but does not seem to change anything. I would describe the suspension as always too stiff ( I own this car since a few weeks and I have no comparison what it should feel like).
The airmatic is working fine, I had just had it repaired as the compressor seemed to work too much and there was a leak somewhere that has been closed. I DON‘T have that common issue of the car losing height overnight or being out of balance. It is just that seemingly non-reacting suspension mode switch.
Can someone point me to some possible sources of the issue that I can relay to my mechanic?
Thank you very much!
Jan
(excuse my English)
Botus
S500/2010/500
the suspension can lock you out if the compressor stops or a leak is detected and it just maintains the ride height and suspension setting it was at when it went into this safety mode... I think if the way the car is sitting is OK it can stay like this without throwing a light on the dash
pretty sure mine was like this for more than 6 months.... before I loaded the car with a heavy load and it started to play up.... once I had a new compressor the change of both height and firmness on the suspension was back to normal
did the person working on the car have decent diagnostics kit?
Tel: 020 8863 9233
