JakeS77
- Apr 27, 2021
- SLK R171/2007/280
I need to remove the driver's side door panel on my SLK R171 2007 to access the window control unit as it's only operating intermittently. I've removed all the bolts bar one which is well hiddden.
Under the armrest there is a very small flap cut into the door panel and I can feel a screw in there but am not able to see it. I assumed it would be a Torx or if not a Philips threaded screw. But I can't get screwdrivers for either of these types of bolt to marry into the screw head. So I can't undo it and this is all that's stopping me get the door off.
Does anyone have any ideas on how to undo it without taking it to a mechanic? The other door bolts are Torx size 15 but this bolt doesn't seem to be the same.
