Advice needed pls
Mussy
Hi guys iv got an C-class 2.2cdi coupe im going to check the oil but need to take off the cover to get to it wat screw driver do I need to take of the screws? And where is power steering fluid bottle located I need to top that up aswell
Cheers
Ali
I am lost on this, you undo the oil filler cap to put oil in, the power steering pump on the front of the engine has the tank just above it
M
Mussy
sorry mate I meant to say when you open the bonnet there is a plastic Mercedes cover covering the engine which is held on with 4 screws to get to the oil cap I need to take that off what screw driver do I need to undo the screws.
Ellsy Tanners
Mars
The cover is held on by trox 30 screws, however it is not nessesary to remove the cover to top up the engine oil. Use the instrument cluter as a that will tell you how much oil is required.
BlackC55
South coast
C43
Look in your handbook it is ALL in there.
If you cant find the filler cap I suggest you take it to someone who can put oil in for you and show your for the future.
