Advice on storage issues with SL55 please
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by oilman4345, Oct 27, 2012.
  1. oilman4345
    oilman4345 New Member
    8
    Sep 1, 2012
    Aberdeen UK
    Your Mercedes:
    AMG SL55,2003, 5.4 liter
    It is likely that I will move overseas for at least 12-18 months.
    As I will still have my own garage I would intend to keep my SL55 for the times when I am back in this country (a few days every 2-3 months).
    What is the advice regaring the 2 batteries.? I am sure I should disconnect the main battery; however, are there any perceived issues on discnnecting the "electrics" battery?
  2. Naraic
    Naraic Moderator
    10,334
    944
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    Get a charger...like those made by CTEK.
  3. Frontstep
    Frontstep Senior Member
    7,410
    1,300
    Apr 22, 2007
    Your Mercedes:
    T210 320cdi
  4. television
    television Always remembered RIP
    164,074
    310
    Your Mercedes:
    It is the rear one that needs it most, the front one does nothing other than the starter and there is no real common connection, I never had the need to charge my front one ever and I have left it 2 months
    The Ctec is good as said above
  5. Chrishazle
    Chrishazle Senior Member
    3,629
    1,223
    May 25, 2009
    Nr Ashford, Kent
    Your Mercedes:
    Having also been in the oil industry and away for extended periods of time, I have for years kept a battery conditioner on my 968 (which has a factory fitted alarm/immobiliser and electric clock, so left alone the battery would eventually discharge). From memory the longest time between engine starts was about 11 weeks - but I have never had a problem, plus keeping the car on the conditioner seems to extend the battery life!
    CTEK conditioners get good reports - you want an "intelligent" one that shuts off when the battery is fully charged and only kicks back in when needed.
    If money is no object, a carcoon will certainly look after the car - an aquaintance has a Ferrari 620 Scaglietti which is absolutely immaculate, it gets carcooned every winter until the weather improves! As you will be returning every few months, I would think a decent indoor car cover would be enough - keep the dust and spiders off without costing the earth.
  6. OP
    oilman4345
    8
    Sep 1, 2012
    Aberdeen UK
    Your Mercedes:
    Thanks for the advice. I will probably buy a CTEK charger then.
  7. Frontstep
    7,410
    1,300
    Apr 22, 2007
    Your Mercedes:
    T210 320cdi
    There are other makes that do the same thing but whatever suits.
  8. l5foye
    l5foye Member
    22
    Mar 30, 2004
    My son recently bought a car that had been stored for an extended period. It soon developed a serious vibration through the steering. Cause -flat spots on front tyres.
    My advice is to jack the car up ensuring that front wheels are off the ground.
  9. television
    164,074
    310
    Your Mercedes:
    That will go away are a few trips, they need to be got warm so that the rubber can reform, but good advice if away a long time
Share This Page
