Hi All,
Apologies if this has been covered in another thread, I have searched a lot but couldn't find it.
I'm currently in the process of replacing the rear air springs on my S212 with Aerosus units.
The new spring is in place, and now all I need to do is push the air line into the brass connector (or so I'm told).
From the articles, posts and videos I saw before doing this, it seemed as though this literally was a case of just pushing the air line in, giving it a small tug backwards, and it would lock in place.
I can push my air line in what looks like the appropriate distance, but if I give it a pull to see if it's locked, it just pulls back out again, almost as if it's mocking me for expecting it to do anything else.
Every fitting guide I've seen says not to disturb the connector pre-fitted to the new spring (apart from one German video on youtube), it's paint-penned too which would imply it's been torque checked by Aerosus, and they do not provide a tightening torque for it, so I'm fairly convinced I shouldn't be removing & refitting it.
I've tried pushing more & more firmly in case there's a step to be overcome, but it's got to the point I'm concerned about damaging the line.
Has anyone else seen this when fitting Aerosus springs?
Is this normal, and it will somehow lock when the bag is actually inflated for the first time?
Or do I need to just push it in harder than you'd think?
Thanks in advance!
Thanks in advance!
