Jonski
I just changed all the brake pads on my 2000 W210 E320CDI. When changing the pads, I opened the bleed screws on the front calipers to let out the fluid when pushing back in the pistons. I did not do this for the rear calipers.
Following the pad change, the brake pedal now goes slowly but steadily to the floor when the engine is running. Pumping it brings it back up, but it again steadily sinks down to the floor.
I have tried bleeding all four calipers (I pumped through about a pint of brake fluid all together) and though the pedal is firmer now, it still goes slowly down to the floor when the engine is running.
I've heard rumours about dirty fluid going back up the line, (when pistons are pushed back in for a pad change) and this maybe causing such problems.
Has anyone else had this problem, any ideas for a solution please?
