Ian-G1
- Sep 1, 2024
- C220 CDI Elegance W204.202 2010
I picked up a cheap C220 (2010) about a month or so ago. Had quite a few faults but low mileage.
But will I ever learn! It started with a cheap DPF Sensor on eBay for £20 …that didn’t work. Went to Mercedes and got the correct part and paid c£90. That worked in so far as a sensor fault was solved.
Fuel filter housing leaking, replaced with a cheap one from eBay £20 - fine until the coolant system was pressure tested ..leaked!!. Mercedes only £43 for the genuine fuel filter housing - I fitted that and the leak cured.
Needed new hub assemblies …went to Autodoc for what I thought was a bargain at £50 per hub. Got ESP and ABS faults and the brake calliper bracket needed washers to stop it catching the disks. So back to Mercedes for the entire hub assemblies x2 £380. Those worked.
I still have the differential pressure warning and I’ve tried everything I can think of….including a forced regen ,(according to my scanner soot and ash are optimal) , no leaking sensor hoses, renewed with genuine Mercedes ones this time to rule that out. I’ve had the EGR off and cleaned with Wynns DPF cleaner. Also DPF cleaner down the sensors tubes. Wired in a new updated Mercedes socket for the sensors as well..all to no avail. If it’s a cracked DPF then Mercedes want £780 - aftermarket at £500.
Think I’ve learned my lesson now. The lure of saving £££s has been a false economy in my case, not to mention the labour involved which granted I do myself but it’s very time consuming.
Just a heads up for those thinking aftermarket will save money, in my case it has cost me a lot more.
