Afternoon maintainance
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Spent a useful afternoon servicing my wiper mechanism on my W210 - thanks to Parrot for detailed info. Also removed the undertray to inspect my cross-member, luckily it was fine, I coated the cross-member with a generous coating of wax oil and made up four plastic spacers on my lathe so that on assembley there was room for any water to drain away. Also I drilled a 8mm hole in the undertray just in front of the cross member to aid drainage of any excess water.
A job well done and anyone with the same car should have a look just in case there is any lurking problems afoot :rolleyes:
Nice feeling isnt it when it all goes well and constructive :D:D
MIW615
MIW615
Leafy Surrey
C200 SPORT & 230SLK
What did you make the bushes out of, just curious
I had a small length of nylon rod so I turned down two spacers 5mm thick with a 12mm diameter and bored 4mm hole - to keep them in place I glued them to the underside of the undertray which made refitting easy.
I guess as an alternative you could use the plastic nuts that are used on number plates - would do the same job. ;)
As the likes of you and I know what trapped water does to metal, is it that the modern wizz kids that design these do not know this.
Good thinking and thanks for posting it
