air con fan
clivehart
I have a 1997 clk 230 kompressor sport which when you switch the air con on only the right hand fan starts. Ive put a power source to the left hand fan and it runs ok but just not on its own. Sides given are when sat in car any ideas please.
Hello and welcome,,do you mean the the fan for the heating in the car
C
clivehart
When you stand at the front of the car the two fans that you can see through the grill the left one works when the air con is switched on but the right one does not but it works when power is connected direct hope this helps
This could be the 2 stage set up,,and the second fan does not start till the temp is 110c when the air con is on
C
clivehart
ok thanks for that im sure they both used to run but prehaps im mistaken thanks for your help great site !
If you care to pop up the VIN numbers after 208
The weather being cooler right could be the reason
with the number I will take an exact look for you
C
clivehart
the vin number is WDB2083472F009566 is the number you mean ?
Yes I have checked again and it is the 2 stage set up,,it has been cooler of late, and this could be the reason
C
clivehart
thanks for your help malcolm much appreciated !
vijilants
London
W204 C320 CDI Sport
Malcolm, do you have a copy of the procedure for testing the fan operation ?
If so id be interested in a copy.
I can do a print off,,you may have to remind me tonight
vijilants
London
W204 C320 CDI Sport
Great...many thanks....can you email it to me ? Ive PM ed you my chassis number.
Top Cat
Milton Keynes
(97) W202 C230 Elegance Estate
Just found this old thread and I had a similar question - as it is obviously colder still at this time of year, is it possible that A/C (in general terms) would operate without either fan having to be on? I ask as I have another vehicl in the family which is doing just this.
Oh yes they are controlled by both temp and pressure, the fan only comes on when needed and does not run all the time
www.ckinsurance.co.uk
