Air Con Problem
beef
Hi to all
Ive got a c class w202. 1999.The air con is not blowing out nice cold air as it should ,out of any of the vents only warm air.So i took to have it re-gassed/checked. They told me that i had no leaks and the system seemed to work fine but no cold air coming out? after waiting to leave the garage i put the air con on and it worked nice cold air,but this was not to last ,1 minute later it started to blow warm air again so on the way home i noticed that when i turn the heater blower switch to off, it keeps blowing(i can hear the fan working) it only stops when i turn the ignition off. and when i turn the ignition back on the fan starts blowing again even with the fan switch turned off!!!!!! I really would like some help on this many thanks
B
beef
  • #2
Hi to all
:rolleyes:After looking at a few threads on air con etc. i replaced the pollen filter .But the fan would not turn off!!!!( by the switch) So i thumped the dash by the passengers air bag and the fan stopped.turned the fan switch to 5 and than back to 0. and it turns off its working at the mo.
Any ideas why by hitting the dash the heater switch works is there a broken wire or do i need a new heater switch control panel???? please help:confused:
