air suspension fault
thebob34
S 280
Hi, could any of you good people please spare a min to read this. Last week while on our way to a concert my s280 came up with a message saying pull over. vehicle too low. As I was on the motorway and near the hotel, I managed to get their slowly. when I tried to go above 50 mph it wouldnt let me, I presume it was a saftey cut out. Anyway, next morning it was really low on drivers side, wheel nearly touching bodywork. I called breakdown and got it recovered home. I took it to a local garage who said a sensor had gone. They replaced it but said it needed re-booting at merc. I took it to another dealer who has the merc comps ect and he said it is coming up with fault code c1327.says on his report the following. The magnetic valve is located on the compressor unit and is the central control unit for the level regulation and activation of the suspension and supplies the suspension legs with pressure air. He says these are very expensive.does anyone know how much these are and how bad this fault is. I have the car back now while we try to get a part. it didnt come up with the pull over message on way home but again it wouldnt let me go over 50. Am i right in thinking its cos of this part again.
Thank you all in advance,
rob (UK)
OlafMaxwell
Cork Ireland
W210 E320 CDI Estate
I dont know too much about the air suspension other than I know it can be both troublesome and expensive. If you get a really heavy quotation as far as I know there is an aftermarket conversion to convert back to standard suspension which is far less troublesome. Not as smooth on the ride but easier on the pocket.
Does the car lower,,,there is another code on this with another fault
The only one that I have with a speed reduction Fault is the pressure relief valve, where the car cannot lower
T
thebob34
S 280
Thanks for the reply. the car is low on drivers side and doesnt seem to move any higher. when you press the air button on the dash it does nothing, although you can hear something
A
andy@pcd-ltd
I would have to say the airmatic pump has burnt out and requires replacing along with the relay.
It is quite an easy job to do
nialler
Dublin
Hi Bob
Same thing happened to me in my S320, airmatic pump had failed, had it replaced for around €270 including labour, there's also sensors on the suspension struts that give a reading to the computer on the level of the car they'll need to be done also as they may give an incorrect reading and lower the level on one side.
T
thebob34
S 280
Hi, all.you were right bout the pump burning out. cost £242 to buy. total bill was only around £325 so I am happy enough at that. didnt know that there was also a re-call on that model so they have sorted it out. something could have caught fire to do with the alternator. hope everyone is aware of this.
bob
rafstar85
Witney, U.K
S350
bob
hey bob
i believe i got the same problem on my S350. but mercedes benz workshop qouted my close to £800. that to replace the compressure and a valve on the airmatic suspension.
but you got it done for close to £325. how?
T
thebob34
S 280
air suspension
Hi all, just when I thought this was all sorted. when you drive now, you can hear it going on and off like a tank. used to be as quiet as a mouse and its brand new pump. any ideas. I am most likely going to main dealer with it now, sick of running bacwards and forwards to garage
T
thebob34
S 280
hey bob
hi, because the part is only £212 + vat for the whole unit new from mercedes. I would get another garage to buy the part off them and carry out the work like I did. there was hardly any labour cost, all I know is they may have to nip it back to merc dealer to have the fault memory erased, if they don't have the software.
ps, sorry for late reply
Cole@MBS
www.mbssouthampton.co.uk
The common fault for the noise Bob, the mech breaks the 6mm studs off and cable ties the pump to the chassis!! hence the load noise!!!!!
