hi all, srs light & active bonnet & passenger seat airbag switched off warnings all came on dashboard together no crashes etc.. jus had a star programme machine run a test and said internal fault with the airbag ecu/ module together with fault b2207/b2208. Have any of you guys encountered this problem & would you advise buying the replacement ecu/module part off eBay & fitting it yourself or get a specialist would appreciate any advice thanks Sie
