B
br1anstorm
It makes me nervous when the aircon doesn't work - both because of the warnings that work on MB aircon systems ain't cheap, and because I still have, and don't want to abandon, the original R12 system in my 1990 560 SEC.
Until recently the aircon in my car worked fine, but the car has been garaged over the winter. I've just started running it again, and the aircon doesn't work. The compressor clutch isn't engaging.
As there are few cars with aircon where I live (the north of Scotland) and even fewer aircon service technicians, I need to do some initial diagnosis if I can. What should I check, and how, to establish why the compressor clutch isn't engaging? I assume that the most likely explanations are
(a) some electrical problem - switch, fuse, or wiring (incidentally my car has the two rotary controls, not the row of pushbuttons);
(b) low gas pressure - so a safety cutout is preventing the clutch from activating; or
(c) some mechanical fault with the compressor-clutch itself.
Apart from checking the fuses, how can I test and in what order for possible electrical problems? And is there any way I can check - I have no specialist tools or gauges - on whether the refrigerant is low? I desperately want to retain and preserve the R12 setup if I can, so I'm hoping that this problem is not one which requires complete conversion of the system to R134a.
One other possible clue (but it might be a red herring...) . There are traces of an oily leak on the ground under the car in the area (front left) under the aircon compressor and the power steering and other hydraulic reservoirs. I had assumed that this was indeed most likely to be power steering fluid. But could it be aircon related? I had always assumed that any leaking refrigerant would simply vaporise and disappear into the atmosphere (hence the ozone-layer problem!)
Any advice on basic troubleshooting using essentially eyes, hands screwdriver and a multimeter would be appreciated. Links to tech advice sites, or even better, some pictures, would be even better!
br1anstorm
br1anstorm
