Airmatic conversion
Hoops
2006 cls 320 cdi
Has anyone got a conversion from airmatic to shock and spring on a w219 cls please?????
V6Matty
Newark, Nottinghamshire
Most of the after market suspension manufacturers do a kit I believe, the question however is why would you want to go that route, the airmatic is a great system when all working and isn’t actually that much more cost wise than traditional spring and strut
John Laidlaw
Wirral
Land Rover Discovery 4
as above, not known of anyone go that route with airmatic (a few with ABC but that's understandable!)
mersum1es
Finland
W219 is available at factory set of conventional spring suspension. Why not use them?
Botus
S500/2010/500
what upsets me is the idiots give no idea about the spring rates or damping they've chosen....
if they said ride height, 5mm below comfort, spring rate 8% firmer than how it feels in comfort and 10% firmer damping, I'd always replace with a kit containing real springs...
air suspension doesn't work on our roads.
mostly its just an odd vague unpleasant mix of out of its depth, miss matched confusion. It might just cope on great roads. but we have worn nasty roads and here airmatic doesn't know how to cope 80% of the time and thus its just a catastrophe. as for handling it doesn't even understand what it is.... its just a dangerous wayward mess that doesn't cope at all
the adjustment between comfort and sport is
comfort = uncomfortable out of control wallowing
sport = uncomfortable but brittle mildly wallowing mess
matthew k
Winchester Hampshire
2005 320 cdi Sport 7 seat estate
Must say I wasn't very impressed with my W211 e55's Airmatic. Wasn't any bother and didn't drop etc, but it didn't seem to ride or handle as well as my W211 Sport.
EmilysDad
Bury Lancs
ML350
i disagree.
I like the Airmatic on my car like wise the R Class before it ..... always set to Comfort (unless I'm towing) I like the soft 'wallowing' and as for handling .... it's a 2 tonne plus barge. If I wanted handling I'd have bought a sports car.
John Laidlaw
Wirral
The rear air in my 63 was mighty fine
i disagree.
One with ABC ;)
Botus
S500/2010/500
w221 conversion - where it gives preciously NO information about what they fitted
H
Hoops
2006 cls 320 cdi
The answer to why is my car in comfort mode will rattle your fillings out and rather than spend a lot of money chasing the cause I thought it may be better just to do away with it
EmilysDad
Bury Lancs
ML350
surely fixing the fault will be cheaper than trying to replace the Airmatic
V6Matty
Agree, replacing airmatic with aftermarket is going to cost a couple of thousand if your not doing the work yourself, you then have to have the car told it no longer has airmatic.
Have you had any diagnostics done to find the cause of the hard ride yet?
brandwooddixon
Wolverhampton
S63 Coupe 2014
Apart from possible issues with your airmatic suspension, what profile tyres are you running?
I've always noticed a big difference when I switch from my summer 20" rims to my winter 17" ones!
H
Hoops
2006 cls 320 cdi
Tyres are 245/40 18 front and 275/35 18 on rear
H
Hoops
2006 cls 320 cdi
  • #17
Not sure to be honest..... just thinking there’s so many different parts to the airmatic that could be the cause ‍♂️
H
Hoops
2006 cls 320 cdi
  • #18
Basic diagnosis but not in depth...... the car changes height without a problem...... it’s been suggested that it may use hydraulic pressure to do the height and air for damping but I’m not sure
..it’s been suggested that it may use hydraulic pressure to do the height and air for damping but I’m not sure
You're being misinformed. The hydraulic system is ABC which is not Airmatic. Totally different animals.
ABC is only fitted to S, SL and CL as far as I'm aware (and then not all of them).
Airmatic issues are almost always one of 4 things:
1. Pump (and associated relay)
2. Leaking lines
3. Leaking bags
4. Bad valve block.
Occasionally level sensors can fail but it's not common.
H
Hoops
2006 cls 320 cdi
  • #20
Pump must be working as heights work fine.
Doesn’t lose height so assuming lines ok.
So thinking more valve block ‍♂️
would a faulty valve block give a hard ride???
